The manual cron works, the schedules does not. I have read that sometimes it is an issue with the path or permissions.
Can anybody point me in the right direction? I would have thought logically that if it runs manually it would run with a schedule, but I know next to nothing about cron jobs. Please help Mr. Wizard.
If the cron job runs, but generates an error, it should email that error to the Virtual Server owner.
You should be able to look in your logs, find the time the cron job was supposed to run, and then see if there’s an entry from cron showing that it did run (or at least tried to).
What does the full cron job look like? That is, if you run this command, what output do you see:
