Since the last virtualmin upgrade I am seeing this error when the collect info job runs:
sh: line 1: 27765 Segmentation fault yum info 2> /dev/null
The contents of the perl script /etc/webmin/virtual-server/collectinfo.pl are:
#!/usr/bin/perl
open(CONF, “/etc/webmin/miniserv.conf”);
while() {
$root = $1 if (/^root=(.*)/);
close(CONF);
$ENV{‘PERLLIB’} = “$root”;
$ENV{‘WEBMIN_CONFIG’} = “/etc/webmin”;
$ENV{‘WEBMIN_VAR’} = “/var/webmin”;
chdir("$root/virtual-server");
exec("$root/virtual-server/collectinfo.pl", @ARGV ) || die “Failed to run $root/virtual-server/collectinfo.pl : $!”;
The file has root.root ownership and permissions are -rwxr-xr-x
Any ideas why the error?
Eric
July 26, 2011, 10:38pm
2
Hmm, that’s an unusual problem.
How much RAM does your server have? You can determine that by running “free -m”. If you could post that output here, that’d be great!
Also, what happens if you log in as root, and run the command “yum info” – do you receive output for that, or do you get an error of some sort?
Thanks for the help and you pointed me in the right direction. I found it was the rpmforge repo causing the segfault. It’s apparently a known issue. I am disabling rpmforge for now.
https://bugzilla.redhat.com/show_bug.cgi?id=725798
Eric
July 27, 2011, 1:04am
4
Thanks for the link! If anyone else has that problem, now we’ll know what’s going wrong.
You are welcome! It’s cool to see Dag posting there
That explains the problem I had
