Creating Cron Jobs
I’m sorry I’m confused. I see cron running for server realted, but not for anything else.
This entry from cronlog shows the cronjob is firing on schedule, right?
Does this script run at all? When you run it from the command line (not from cron, not from Webmin, actually login via ssh and run it yourself), does it do what it is supposed to do? At this point, I’m about 95% sure you have a script problem, not a cron problem. We should not be talking about cron when the problem has nothing to do with cron.
I haven’t checked in SSH. I was doing it through Shell in Webmin. I’ll try SSH and post back. TY
I ran on SSH and still nothing.
Then it is definitely not a cron problem.
O.K. Thank you for your help.
