No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.3 LTS
Release: 20.04
Codename: focal
webmin: 1.981
virtualmin: 6.17-3
not pro, community
domain: cashdrone.fr
I try to install a domain DOMAIN using this CLI command
virtualmin create-domain --domain DOMAIN --pass PASS_PASS --desc “1 - BERTRAND Guillaume - DOMAIN” --unix --dir --webmin --web --dns --mail --spam --limits-from-plan --mysql --webalizer --virtualmin-awstats --ssl
and after I search the command to install wordpress default script.
I am sorry maybe I dont search well in the doc.
Do you have this example command in order to create and install wordpress website (using the default script) on my domain ?
Best Regards,
Guillaume BERTRAND
@guillaume5524 ,
You’re probably looking for the following CLI commands:
install-script
delete-script
list-scripts
list-available-scripts
You can learn more about these commands by entering for example:
virtualmin install-script --help
This will show you the available options for the command
Happy holidays!
Thanks a lot:
I am here right now I am searchering the websites directories.
root@websites:~# virtualmin install-script --type wordpress --domain DOMAIN --version 5.8.2 /home/cashdrone/public_html/
i try to pass the website directory
Do you know where is stored is the the website directory ?
Happy holidays !
Best Regards,
@guillaume5524 ,
Adjust to:
virtualmin install-script -domain DOMAIN --db “mysql DBNAME” --path / --type wordpress --version latest
In the above…
DOMAIN implies the domain you want to install script to.
DBNAME would be the name of the database where WordPress would install to.
–path / implies that you want WordPress installed at https://DOMAIN/
–version latest will install the latest stable version of WordPress, much easier then specifying a version unless you want to install an older version (not usually logical)
If you want further explanations and help regarding the “install-script” command, please refer to:
https://www.virtualmin.com/documentation/developer/cli/install_script/
system
Closed
January 6, 2022, 9:25pm
6
