I’m able create custom categories and reassign existing modules under said custom category within “Webmin”. When I do the same for Usermin it doesn’t work. I’m unsure of what it is that I’m doing incorrectly.
After some tinkering I think I found the solution. I need to clone usermin modules under new names and assign them to the custom category?
Ok so when I want to change a custom menu and force it to change the UI for usermin I usually have to clone a module to a new name and assign it to the custom category then somehow the usermin re-reads the config files and updates the UI but it’s not working without doing that whereas when I do it within webmin it works without doing that.
