SYSTEM INFORMATION | |
OS type and version | AlmaLinux 9.2 |
Webmin version | 2.101 |
Virtualmin version | 7.8.2 |
Related packages | cPanel migration |
I am performing cPanel migration of main domain with multiple subdomains. When I am running the migrate process, I was hoping that all main and all sub domains end up with enabled SSL but it does not seem to be happening by default. I must be missing something, can you help.
- I have enabled:
- Request Let’s Encrypt certificate at domain creation time?
- Then ran migrate process, it does not request SSL certificate on creation
- If I enable Generate SSL certificate for domains without SSL enabled?
- Then certificate is generated on migration time, but when I open the website on browser, it has the wrong certificate assigned - the certificate is taken from the existing (different) domain that I have on the server
- I have noticed that going to each main/sub domain → Edit Virtual Server → Setup Apache SSL website, fixes the issue but I need to do this for every domain/sub domain to make it work
I can provide access to my server and the sample cPanel backup as well which is using legitimate domain, so you can validate what’s going wrong.
I have also noticed that when I click on Create Virtual Server, I do not see Setup Apache SSL website under Enabled Features. Is this expected?
