SYSTEM INFORMATION | |
OS type and version | Rocky Linux 8.6 |
Webmin version | 1.994 |
Virtualmin version | 7.1 |
Hi ! I have decided to use virtualmin with rocky linux (I had centos 8). The only problem that I have is that I can’t restore the virtual servers. I am getting the following message:
Checking contents of the backup ..
.. found 1 virtual servers
Starting restore of 1 domains from local file /backup ..
Extracting backup archive files ..
.. done
Re-creating virtual server dev.yourplaceholder.com ..
.. could not work out the default IP address
.. failed! See the progress output above for the reason why.
There is fix for this ? Thank you !!
