Could anyone help me with WordPress MU?
Can you tell me how to install WordPress MU on Virtualmin?
You should be able to use the instructions on the WordPress site to perform an installation. Note that it appears that WordPress MU is no longer a separate project, and that it’s functionality has been combined with the main WordPress branch.
There are instructions for installing WordPress here:
http://codex.wordpress.org/Installing_WordPress
In Virtualmin, you can just create a new Virtual Server, and install Wordpress into the public_html folder of that Virtual Server.
Yeah…I will try it.
But is that also for WordPress MultiUser?
(By the way,can I use WHMCS or BoxBilling to sell Virtualmin GPL Hosting account?)
Yeah…I will try it. But is that also for WordPress MultiUser?
Well, as I mentioned above, WordPress MU no longer exists as a standalone app – it’s functionality has been incorporated into the standard WordPress release.
So if you install WordPress, you can access the features that were previously part of WordPress MU.
That said, both WordPress and what was previously WordPress MU work just fine with Virtualmin.
WHMCS works well with Virtualmin (both Pro and GPL).
I’m not familiar with BoxBilling, so I’m not sure which Virtualmin versions it works with.
Thank you…
I just found that BoxBilling Free Version doesn’t support Virtualmin.
