Connection problems after last update to v6.04
I had this update to v6.04 and now several connecting problems.
  • recheck license, Failed to contact license server HTTP/1.1 404 Not found.
  • yum update runs through many mirrors but seems to have a real problem.
  • logs and report, same failed to connect.
  • Most worrying part is that my Dynu freeddns.org is not allowed in IP Access Control.
This happens on the GPL and Pro servers.
Hmm, are you perhaps seeing a DNS issue?
What output do you see if you run this command:
ping -c 1 software.virtualmin.com
Hiya,
PING software.virtualmin.com.server.com (x.x.x.x) 56(84) bytes of data. 64 bytes from server.domain.com (x.x.x.x): icmp_seq=1 ttl=64 time=0.052 ms
software.virtualmin.com.server.com ping statistics —
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.052/0.052/0.052/0.000 ms
I removed my server IP, but the ping comes back with my own IP instead of the one from virtualmin
OK, am I correct that my CentOS install has his own network settings independent from any virtualmin server server?
EDIT:
PING software.virtualmin.com (163.172.162.254) 56(84) bytes of data.
64 bytes from 254-162-172-163.rev.cloud.scaleway.com (163.172.162.254): icmp_seq=1 ttl=54 time=18.5 ms
software.virtualmin.com ping statistics —
rtt min/avg/max/mdev = 18.555/18.555/18.555/0.000 ms
