Conf. check error: No virtual maps found
Hi all,
Sorry if this is a stupid/obvious problem but…
I just installed 3.52GPL on a Debian 4 VM and the configuration check throws up the following error:
A problem was found with your Postfix virtual maps : No map sources were found in the Postfix configuration
I went into the postfix configuration and configured /etc/postfix/virtual under the virtual domains section. I also configured /etc/postfix/transport under the transport mapping section. Neither setting fixed the problem. I’ve also done some googling but can’t find anything relevant.
Can anyone suggest how I should fix this?
Thanks.
Hi all,
I fixed this. I had manually typed /etc/postfix/virtual in the postfix config instead of using the button-with-three-dots which goes ahead and creates the mapping hash file too.
Doh!
Hey what and where did you put this at in what config file? the main.cf and how does yours look now? I am stumped here on this… Tried everything it a few times so what is it here that needs to be added to fix this?
