help me ,now my server must To restart at least twice a day.
Yeah, by default, collectinfo.pl runs pretty frequently.
One thing you might try is to have it run less often. To do that, go into System Settings -> Virtualmin Configuration -> Status Collection, and set “Interval between status collection job runs” to a larger number.
Sorry to open an old topic but there is an issue with the Virtualmin 4.04
When you try the above setting it asked for checking the configuration of Virtualmin again and when you check it shows error “mine below”
Checking Configuration
Your system has 31.32 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Your Postfix version does not support per-domain outgoing IP addresses.
PHP execution via fcgid requires the Apache mod_fcgid module
