Ok did a fresh install of CentOS 6 Virtualmin pro.
I followed the Dokument about uninstalling for Centos/RHEL but in my case it dint work.
Just wanted to inform you that ive reinstalled OS and dont need support on this ty
For future reference, in case anyone wants to remove Cloudmin…it’s really easy, because Cloudmin is just a Webmin module. Unlike Virtualmin, it does not include or require a big list of dependencies, and doesn’t really do any configuration on the system during install.
On CentOS: rpm -e wbm-server-manager
On Debian/Ubuntu: dpkg -r webmin-server-manager
On other systems, use the Webmin Modules module to uninstall the Cloudmin module.
Also note that it doesn’t do anything if you don’t tell it to, so it doesn’t hurt to have it installed.
