Cloudmin and Virtuamin GPL
Does Cloudmin work with Virtualmin GPL. We have 2 servers running Virtualmin GPL.
We are able to create sites on the first server with API. Can cloudmin help ‘replicate’ these sites on the second machine, merge the two logs and get proper resource tracking, AWSTATS etc?
Yes and no. Cloudmin works fine with Virtualmin GPL (some of the analytics data is only available from Professional, though).
But, replication doesn’t do what you’ve described. Replication makes a “spare” system, it does not make any attempt to turn them into a cluster or to make them work in tandem. Currently, it is for redundancy/reliability, and not for scaling. Scaling across multiple servers is a complex problem that we haven’t even begun to really address (and in a lot of cases, we can’t; applications have to be built to scale, and we don’t have any control over your applications).
