System Info:
Cloudflare without proxy (http://) works, but as soon as I switch to proxied (https://) and “flexible” SSL activated, it shows a Error 520 page.
Is there some settings I can edit?
System Info:
When I switched from “flexible” SSL to “full” SSL in Cloudflare it worked better. As the website also is encrypted with LetsEncrypt.
That was the only reason I didn’t reply. You said:
And that’s usually what it always is: people use Full or Full strict. It’s usually the other way around that causes the problem.
