I have tried several times and using varying methods to get ClamAV upated. The version installed with VirtualMin is “ClamAV 0.95.2/11014/Fri May 14 07:59:17 2010”. The current package available from VirtualMin is 0.96.1.
But I get the following errors below when I try to update. An easier to read version in PDF format is attached. PLEASE ADVISE SOLUTION THANK YOU!!:::
Now updating clamav …
Installing package(s) with command yum -y install clamav …
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- addons: mirror.web-ster.com
- base: mirrors.cat.pdx.edu
- extras: mirrors.easynews.com
- rpmforge: apt.sw.be
- updates: mirror.hmc.edu
Setting up Install Process
Resolving Dependencies
–> Running transaction check
—> Package clamav.i386 0:0.96-3.el5.rf set to be updated
–> Processing Dependency: clamav-db for package: clamav
–> Processing Dependency: clamav-lib = 0.95.2-1.vm.el5 for package: clamav-server
—> Package clamav-db.i386 0:0.96-3.el5.rf set to be updated
–> Processing Dependency: clamav-server = 0.95.2-1.vm.el5 for package: clamav-server-sysv
—> Package clamd.i386 0:0.96-3.el5.rf set to be updated
—> Package clamav-server-sysv.i386 0:0.96-1.vm.el5 set to be updated
–> Processing Dependency: clamav-server = 0.96-1.vm.el5 for package: clamav-server-sysv
—> Package clamav-server.i386 0:0.96-1.vm.el5 set to be updated
–> Processing Dependency: clamav-lib = 0.96-1.vm.el5 for package: clamav-server
–> Processing Dependency: clamav-filesystem = 0.96-1.vm.el5 for package: clamav-server
—> Package clamav-filesystem.i386 0:0.96-1.vm.el5 set to be updated
—> Package clamav-lib.i386 0:0.96-1.vm.el5 set to be updated
–> Processing Conflict: clamav-filesystem conflicts clamav > 0.96-1.vm.el5
–> Finished Dependency Resolution
clamav-filesystem-0.96-1.vm.el5.i386 from virtualmin has depsolving problems
–> clamav-filesystem conflicts with clamav
Error: clamav-filesystem conflicts with clamav
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
… install failed!
Now updating clamav-data …
Installing package(s) with command yum -y install clamav-data …
- updates: mirrors.cat.pdx.edu
—> Package clamav-data.i386 0:0.96-1.vm.el5 set to be updated
–> Processing Dependency: clamav-filesystem = 0.96-1.vm.el5 for package: clamav-data
–> Processing Dependency: clamav-filesystem = 0.95.2-1.vm.el5 for package: clamav-update
–> Processing Dependency: clamav-filesystem = 0.95.2-1.vm.el5 for package: clamav-server
–> Processing Dependency: clamav = 0.96-3.el5.rf for package: clamd
… install failed!
Now updating clamav-filesystem …
Installing package(s) with command yum -y install clamav-filesystem …
–> Processing Dependency: clamav-filesystem = 0.95.2-1.vm.el5 for package: clamav-data
–> Processing Dependency: data(clamav) for package: clamav
–> Processing Dependency: data(clamav) for package: clamav-lib
… install failed!
Now updating clamav-lib …
Installing package(s) with command yum -y install clamav-lib …
… install failed!
Now updating clamav-server …
Installing package(s) with command yum -y install clamav-server …
- addons: mirror.nic.uoregon.edu
–> Processing Dependency: data(clamav) for package: clamav-server
… install failed!
Now updating clamav-server-sysv …
Installing package(s) with command yum -y install clamav-server-sysv …
… install failed!
Now updating clamav-update …
Installing package(s) with command yum -y install clamav-update …
—> Package clamav-update.i386 0:0.96-1.vm.el5 set to be updated
–> Processing Dependency: clamav-filesystem = 0.96-1.vm.el5 for package: clamav-update
… install failed!
No packages were installed. Check the messages above for the cause of the error.
