Hi
I wanted to update my Linux installation (yum update) and now I get the following error:
—> Package clamav-data-empty.i386 0:0.95.2-1.vm.el5 set to be updated
–> Processing Dependency: clamav-server = 0.95.2-1.vm.el5 for package: clamav-server-sysv
—> Package clamd.i386 0:0.96-1.el5.rf set to be updated
–> Processing Dependency: clamav = 0.96-1.el5.rf for package: clamd
—> Package perl-Compress-Raw-Bzip2.i386 0:2.024-1.el5.rf set to be updated
—> Package perl-Compress-Raw-Zlib.i386 0:2.024-1.el5.rf set to be updated
–> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base
–> Finished Dependency Resolution
virtualmin-base-1.0-61.rh.noarch from installed has depsolving problems
–> Missing Dependency: /usr/bin/freshclam is needed by package virtualmin-base-1.0-61.rh.noarch (installed)
clamd-0.96-1.el5.rf.i386 from rpmforge has depsolving problems
–> Missing Dependency: clamav = 0.96-1.el5.rf is needed by package clamd-0.96-1.el5.rf.i386 (rpmforge)
clamav-server-sysv-0.95.2-1.vm.el5.i386 from installed has depsolving problems
–> Missing Dependency: clamav-server = 0.95.2-1.vm.el5 is needed by package clamav-server-sysv-0.95.2-1.vm.el5.i386 (installed)
Error: Missing Dependency: clamav-server = 0.95.2-1.vm.el5 is needed by package clamav-server-sysv-0.95.2-1.vm.el5.i386 (installed)
Error: Missing Dependency: clamav = 0.96-1.el5.rf is needed by package clamd-0.96-1.el5.rf.i386 (rpmforge)
Error: Missing Dependency: /usr/bin/freshclam is needed by package virtualmin-base-1.0-61.rh.noarch (installed)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
Any suggestions what I can do? Tried already skip-broken, and the package-cleanup things.
Best regards
Ivan
