I have installed manually Webmin and then Virtualmin. Webmin was working OK. Then I have re-checking configuration for Virtualmin to the point where I have no clue what to do next.
Here is status message:
The status of your system is being checked to ensure that all enabled features are available, that the mail server is properly configured, and that quotas are active ..Your system has 3.74 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Your Postfix version does not support per-domain outgoing IP addresses.
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
Thanks for any help.
