SYSTEM INFORMATION | |
OS type and version: | Ubuntu Linux 20.04.3 |
Webmin version: | 1.981 |
Virtualmin version: | 6.17-3 |
Related products version: | Usermin version 1.823 |
Halo
I installed Virtualmin through the same link (Downloading and Installing Virtualmin – Virtualmin)… the installation was done without problems…
But I get a message during Checking Configuration:
“…your system is not ready for use by Virtualmin.”
Is there a solution to this?
Full text:
Your system has 7.63 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB.
Postfix is configured to support per-domain outgoing IP addresses.
Apache is installed.
The following PHP versions are available : 7.4.3 (/bin/php-cgi7.4)
The following PHP-FPM versions are available on this system : 7.4.3 (php7.4-fpm)
The following PHP execution modes are available : none cgi fcgid fpm
PHP versions have changed to 7.4 since last check. Regenerating any missing php.ini files.
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL 8.0.27-0ubuntu0.20.04.1 is installed and running.
ProFTPD is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
The procmail command in the Postfix configuration does not exist.
