Changing passwords of svn users
I´ve installed “Virtualmin” with “Virtualmin Subversion”. It works great. The problem is that when a user tries to change his password from webmin, all password are changed except on the “Virtualmin Subversion”. I tried to find the solution to this on this forum and on google but i coulnt find anything. The only way of changing the password is by ssh with the htpasswd command? I would like that the password of this users also change with the webmin password. Are there any hack or configuration for this?
Thanks in advance.
Notero
Hrm, I don’t see any alternative ways of changing it if the Change Password option in Virtualmin isn’t updating the SVN password.
I might recommend filing a bug report using the Support link above, and Jamie can take a look at that :slight_smile:
Thanks!
Hi Eric,
Ok. I will. Anyway if anyone could give me a clue of what is the problem or at least where can i look for it. Could it be in /usr/libexec/webmin/virtualmin-svn/virtual_feature.pl ?
Thanks!
Solved on https://www.virtualmin.com/node/11214
