I am writing a script installer for my php application, which is based on laravel. It will be deployed to the lemp stack, and for the installation to work, I need to make these changes to the nginx settings:
- Replace all public_html with public_html/public in the file /etc/nginx/sites-available/$domain.conf
- Add the following code line:
location / { try_files $uri $uri/ /index.php$is_args$args; }
This is what I am doing currently in the script_name_install:
$domain = &get_domain_http_hostname($d);
local $nxcfg = "/etc/nginx/sites-available/$domain.conf";
$public = "public_html\\/public";
$php = 'location \/ { try_files \\$uri \\$uri\/ \/index.php\\$is_args\\$args; } \\n\\t';
# Nginx settings
local $cmd = "sed -i \"s/public_html/$public/g\" $nxcfg; ";
$cmd .= "sed -i \"s/root/$php root/g\" $nxcfg; ";
$cmd .= "nginx -s reload";
system($cmd);
but somehow the nginx config file getting messed up AFTER my changes, something like missing brackets or it has now two lines of fastcgi_read_timeout like:
fastcgi_read_timeout 60; # This is the original
fastcgi_read_timeout 9999; # This is being added later, no idea why!
So my question is: what is the best way to change the nginx settings please?
Also: where can I change the template of the nginx config for the domains? And can I have multiple config files for multiple hosting plans?
Thank you!
