I have set up virtualmin and have installed Lucee on the same server which is used for coldfusion . now I need the home directory for virtualmin to point to Lucee webapps folder
/opt/lucee/tomcat/webapps
because Lucee runs all it’s backend through that folder . my question is how do I change the home folder (including file manager) to see that folder.
I have changed document root to this address in httpd.conf but that did nothing. any help would be appreciated.
Ok I went to: Virtualmin > Server Configuration > Change Domain Name and adjusted “Change home directory” which worked great but the top folder (e.g.domain.com) is where files need to be. Virtualmin has put public_hmtl into that folder so to browse you have a url that looks like this. http://domain.com/public_html/index.cfm.
If this is the only virtual server that will need an odd path, just change it in the Apache configuration. Where that is depends on your OS/version, either /etc/httpd/conf/httpd.conf or /etc/apache2/sites-available. Find the DocumentRoot and Directory directives and remove the public_html bit from them. (There may be multiple instances you need to change, if you have SSL enabled.)
If you want new domains to use a different docroot, use Server Templates to change it, under the Apache website section.
Hi Joe . actually I got it all to work perfectly just leaving everything standard on virtualmin and updating the httpd.conf file with the normal Lucee structure .
I don’t know if you are able to but I would like a way to open one folder to lower accounts which is in opt/path… Is this possible. I am a programmer so I can change the code if you could show me how. I run lucee (coldfusion) so their html folder is not in public_html. I need to allow them access to the webapps folder in the opt/path… folder
