Well, there’s no simple way to do that… typically, folks running Virtualmin would would use the default A/MX records that have email pointing to itself.
The only way I can think of to accomplish that would be if you went into System Settings -> Server Templates -> Default -> BIND DNS Domain, and you configured “BIND DNS records for new domains” with all the DNS records you wanted to use. You’d have to set “Use only the records above” with that option.
However, it’s fairly rare that anyone would need that… in fact, I think you’re the first to ask
Is there a particular problem you’re trying to solve? I’m curious if maybe there’s a different way to go about that.
Like Eric said – When Virtualmin is configured to receive mail for a server (by turning on that feature), it will instruct Postfix accordingly, and create the MX record pointing to itself. That’s the only thing that makes sense in this case.
If you want a different MX (which can of course happen if you wish to use an external mail server – some of my customers have their zones set up to use Google Mail), you a) need to turn off the “Mail for domain” feature, and b) add a custom BIND entry, directly to the existing server in question, or to the template for new servers like Eric explained.
