Hi, I wanted to migrate a server’s script into virtualmin, so I cheated a bit. I…
- upgraded to the same version as Virtualmin
- moved the files out of the way
- installed the script using virtualmin
- deleted the virtualmin files and replaced with customer’s product
This worked wonderfully, except I had virtualmin create a temporary db while it installed. Now when I look at the script through virtualmin, it lists the wrong db and I was wondering if anyone knew where I can correct that.
Thanks, in advance.
