After last update all source code of my websites was available in plain text (which used cgi/fcgid). That’s NOT good
And now I can not switch back to fcgid and I get source code…
That implies some sort of configuration problem. What distro/version are you using?
And if you go into Server Configuration -> Re-Check Config, does it notice any problems?
nope. … your system is ready for use by Virtualmin.
I will stick with mod_php for a while now…
Centos 5.8 x64 + PHP 5.4.9 from Remi repo
