Hey!
I have this problem when I’m trying to use alias domain…
Requesting a certificate for domain.fi, domain.com, www.domain.com from Let’s Encrypt …
Parsing account key...
Parsing CSR...
Registering account...
Already registered!
Verifying domain.com...
File "/usr/libexec/webmin/webmin/acme_tiny.py", line 235, in
main(sys.argv[1:])
File "/usr/libexec/webmin/webmin/acme_tiny.py", line 231, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, args.dns_hook, args.cleanup_hook, log=LOGGER, CA=args.ca)
File "/usr/libexec/webmin/webmin/acme_tiny.py", line 144, in get_crt
resp = urlopen(wellknown_url)
File "/usr/lib64/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib64/python2.7/urllib2.py", line 437, in open
response = meth(req, response)
File "/usr/lib64/python2.7/urllib2.py", line 550, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib64/python2.7/urllib2.py", line 469, in error
result = self._call_chain(*args)
File "/usr/lib64/python2.7/urllib2.py", line 409, in _call_chain
result = func(*args)
File "/usr/lib64/python2.7/urllib2.py", line 656, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/usr/lib64/python2.7/urllib2.py", line 431, in open
response = self._open(req, data)
File "/usr/lib64/python2.7/urllib2.py", line 449, in _open
'_open', req)
File "/usr/lib64/python2.7/urllib2.py", line 1258, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/lib64/python2.7/urllib2.py", line 1211, in do_open
h.request(req.get_method(), req.get_selector(), req.data, headers)
File "/usr/lib64/python2.7/httplib.py", line 1017, in request
self._send_request(method, url, body, headers)
File "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
self.endheaders(body)
File "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
self._send_output(message_body)
File "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
self.send(msg)
File "/usr/lib64/python2.7/httplib.py", line 826, in send
self.connect()
File "/usr/lib64/python2.7/httplib.py", line 1236, in connect
server_hostname=sni_hostname)
File "/usr/lib64/python2.7/ssl.py", line 350, in wrap_socket
_context=self)
File "/usr/lib64/python2.7/ssl.py", line 611, in __init__
self.do_handshake()
File "/usr/lib64/python2.7/ssl.py", line 841, in do_handshake
match_hostname(self.getpeercert(), self.server_hostname)
File "/usr/lib64/python2.7/ssl.py", line 273, in match_hostname
% (hostname, dnsnames[0]))
ssl.CertificateError: hostname 'domain.com' doesn't match 'domain.fi'
Any ideas how I can request these certificates? or what that error msg even means…
