Hi guys
I have just moved a customer off my old 32bit box and onto my shiney new Virtualmin pro box (64bit) and all seemed to be going well. He used some image tool called gd and on the new box php doesnt seem to know about it. Is there any way i can get it working for him?
gd is installed but it is in the lib64 folder rather than the lib folder. Any ideas?
I have installed that but the customer is still having problems.
When i view the old servers phpinfo.php about 3 quarters down the page it has a section specifically for GD, here is a copy and paste
gd
GD Support enabled
GD Version bundled (2.0.28 compatible)
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
XBM Support enabled
When i view my phpinfo.php on the current server it hasnt got that subsection. Sorry if i am not being very specific but im not sure what these sections are called.
Do i have to recompile php with gd installed?
Did you compile your own PHP? If so, then yes, and you need to install the gd-devel package (before rebuilding PHP). If you installed from RPM it should just work.
Will tell you. I’m not really all that savvy about php…so I might be missing something that needs to be done to make it recognize the module, but you definitely shouldn’t have to reinstall php.
You probably do have to restart Apache, though, unless using php as a CGI script.
