Here is the story.
Fresh install of Centos 6.2 on ESXi 4.1
ran yum update
installed vmware tools
ran the install.sh for virtual min and got this error:
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - 2012-11-24 09:52:48 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2012-11-24 09:52:48 - Cannot continue installation.
FATAL - 2012-11-24 09:52:48 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-11-24 09:52:48 - re-attempted after any problems have been resolved.
FATAL - 2012-11-24 09:52:48 - Removing temporary directory and files.
FATAL - 2012-11-24 09:52:49 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-11-24 09:52:49 - in /root/virtualmin-install.log
INFO - 2012-11-24 09:59:33 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-11-24 09:59:34 - Install mode: full
DEBUG - 2012-11-24 09:59:34 - Product: Virtualmin GPL
DEBUG - 2012-11-24 09:59:34 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-11-24 09:59:34 - install.sh version: 1.0.9
INFO - 2012-11-24 09:59:34 - Checking for fully qualified hostname…
INFO - 2012-11-24 09:59:34 - Hostname OK: fully qualified as webserver.joshg678.com
INFO - 2012-11-24 09:59:34 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-11-24 09:59:34 - Loading OS selection library…
INFO - 2012-11-24 09:59:34 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-11-24 09:59:34 - Loading OS list…
INFO - 2012-11-24 09:59:35 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-11-24 09:59:35 - Operating system name: CentOS Linux
INFO - 2012-11-24 09:59:35 - Operating system version: 6
INFO - 2012-11-24 09:59:35 - Configuring package manager for CentOS Linux 6…
INFO - 2012-11-24 09:59:35 - Disabling SELinux during installation…
DEBUG - 2012-11-24 09:59:35 - setenforce 0 succeeded
INFO - 2012-11-24 09:59:35 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2012-11-24 09:59:36 - Succeeded.
INFO - 2012-11-24 09:59:36 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL qu
ota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mys
ql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple pe
rl-Crypt-SSLeay
Loaded plugins: fastestmirror, security
FATAL - 2012-11-24 09:59:58 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2012-11-24 09:59:58 - Cannot continue installation.
FATAL - 2012-11-24 09:59:58 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-11-24 09:59:58 - re-attempted after any problems have been resolved.
FATAL - 2012-11-24 09:59:58 - Removing temporary directory and files.
FATAL - 2012-11-24 09:59:58 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-11-24 09:59:58 - in /root/virtualmin-install.log
I can post the the entire log if it helps, but these are the only errors i could find.
