–> Finished Dependency Resolution
30:bind-9.3.6-16.P1.el5.x86_64 from rhel-x86_64-server-5 has depsolving problems
–> Missing Dependency: liblwres.so.9()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
–> Missing Dependency: libisc.so.15()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
–> Missing Dependency: libbind9.so.0()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
–> Missing Dependency: libdns.so.26()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
–> Missing Dependency: libisccfg.so.1()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
–> Missing Dependency: libisccc.so.0()(64bit) is needed by package 30:bind-9.3.6-16.P1.el5.x86_64 (rhel-x86_64-server-5)
You could try using --skip-broken to work around the problem
This is, to my knowledge, a stock centos 5.5 install. I’d installed the GPL version last week on (what I was told was) an identical server (our test environment) and it worked fine. Pulling down the installer today and running install.sh I get this. Not sure quite what this is indicating or how to get around it. Any pointers/help/advice?
Thanks.
