my vps is running centos 7 and I have a question regarding phpmyadmin
I have created a virtual server for my hostname and have phpmyadmin installed on it (using install scripts). The idea is to have only 1 phpmyadmin installed and all virtual servers will use this to login to phpmyadmin.
when I go to hostname.mydomain.com/phpmyadmin, it loads fine. The problem is some users can login but some can’t.
ie. I have the following virtual servers created:
domain1.com
domain2.com
domain3.com
and all are created using the same plan, same server template.
when these domains are created, the default users are also created. ie. domain1, domain2, domain3.
The problem is, some default domain users can login to phpmyadmin without any problem, but some default domain users can’t. For those that can’t login, I’ll have to create a new user, grant access to the associated mysql database.
Why is that?
