This is the only thing listed in miniserv.error for today.
[08/Feb/2011:16:39:44 +0000] miniserv.pl started
[08/Feb/2011:16:39:44 +0000] PAM authentication enabled
just rebooted server and still nothing, the the one website on the server is working.
Yeah, that’s pretty unusual… the first thing I’d check is to make sure that Webmin is indeed listening on port 1000. You can do that by running this command:
netstat -an | grep :10000
After running that, what output do you get?
If you see something like this:
tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN
That means Webmin/Virtualmin is working properly, and the issue may be due to a firewall or similar in front of your server that’s blocking that port.
It looks like all your firewall rules were added by fail2ban. If clearing out iptables solves the problem, you should probably review fail2ban and make sure it’s working the way it should
One way to clear out all the iptables rules would be to run the following commands:
On some distros, you can simply use the iptables init script and stop it – but the key is to make sure that the policies for all your chains are set to ACCEPT, which the above would do.
Yes that fixed it. I cleared the firewall rules and it worked.
Where is the access log for the control panel, I want to check to see if there was an attack of some kind on the login screen?
