So i have CentOS 6.4 server with Webmin/Virtualmin installed on it.
I disabled the Apache and installed Nginx but i cant install its modules for Virtualmin as per instructions here:
The “wbm-virtualmin-nginx” package is a package contained in the Virtualmin software repository… that’s available if your server is configured to use that particular repository.
How did you install Virtualmin – did you do that using the install.sh script? If you didn’t use the install.sh script, that might explain why you’re not seeing that package.
Actually i wanted it clean so i installed Virtualmin as a Webmin module.
However i have found the file for the Nginx module and installed it manually through Webmin.
