Can't add Procmail filters through Webmin module
According to http://doxfer.com/Webmin/ProcmailMailFilter, there is supposed to be an “Add new filter action” link, but it doesn’t show up for me.
I’ve attached a screenshot of what I see, but in case it doesn’t show up, here’s a link: http://www.mediafire.com/i/?w2z5qgm5yji
Can anyone help me get those links to show up?
Thanks!
Grant
In order for that to work, your system would have to be configured to use Procmail for mail delivery.
It sounds like you’re using Webmin, and not Virtualmin, is that correct? The installation of Virtualmin when using the install.sh script would generally setup Postfix along with procmail on your server… but that’s not something you’d want to do on a live server :slight_smile:
Essentially though, you’d want to make sure that whatever email system you’re using (Postfix, Sendmail, or whatever), that your server has procmail enabled.
