can not receive email problems
Hi Friends~
i tried reinstalled virtualmin and opened domain email, etc.
and seems now can send an email with the account added,and can login into squirrel mail installed correctly,
but problems is can not receive an email~
so what problems with this,should i open other functions and plugins?
thanks all`
Dark
This message was created automatically by mail delivery software. A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed: info.teddybirds@teddybirds.com ------ This is a copy of the message, including all the headers. ------ Return-path: Received: from localhost ([::1] helo=[5.9.176.33]) by ayane.sitesten.com with esmtpa (Exim 4.76) (envelope-from ) id 1WzFXb-0004K5-Nz for info.teddybirds@teddybirds.com; Mon, 23 Jun 2014 18:28:56 -0700 Received: from 1.50.243.197 (SquirrelMail authenticated user webmaster@.net) by 5.9.176.33 with HTTP; Tue, 24 Jun 2014 01:28:55 -0000 Message-ID: <16cf5e4a1fe0841eb73267c2ee694fb4.squirrel@5.9.176.33> In-Reply-To: <202b0673b8c5c51037fe43d9607a908b.squirrel@teddybirds.com> References: <202b0673b8c5c51037fe43d9607a908b.squirrel@teddybirds.com> Date: Tue, 24 Jun 2014 01:28:55 -0000 Subject: Re: test etc From: "Dark" To: info.teddybirds@teddybirds.com Reply-To: webmaster@.net User-Agent: SquirrelMail/1.4.22 MIME-Version: 1.0 Content-Type: text/plain;charset=iso-8859-1 Content-Transfer-Encoding: 8bit X-Priority: 3 (Normal) Importance: Normal
The text you quoted unfortunately does not contain the actual error message from the delivering mail server, only the “it didn’t work” message and a copy of the original headers.
It’d be important to see the actual error message. The delivering server should say what went wrong (e.g. “Domain name not found”, “Connection failed”, things like that).
wow,thanks Locutus~
it mail said subject “Mail delivery failed: returning message to sender”
so what do you guess is the problems, i am new both to virtualmin and vps too…
thanks help and chances to learn from yours all!
Dark
Hmm… Unfortunately, it’s next to impossible to guess that without further information.
As I said, the delivering server usually states in its non-delivery report what went wrong, like connection failure, email was refused, the error code it got from your server etc.
Without that info, it’s pure guesswork. So you should do two things: Try to send an email and let us know the full error message from the delivering server, and check the mail logfiles of your server at the time of delivery attempt.
