Centos 6.5 64bit
After some recent updates discovered that package nss-softokn-freebl is always showing for “to be updated”. When trying to install it throws an error.
So I have removed it via console rpm command.
Now it has broken Yum and wont install anything (File /usr/lib64/libfreebl3.so is missing). This .so file is part of nss-softokn-freebl-3.14.3-3.el6_4.x86_64 and nss-softokn-freebl-3.14.3-3.el6_4.i686 packages.
yum update
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
libfreebl3.so: cannot open shared object file: No such file or directory
Please install a package which provides this module, or
verify that the module is installed correctly.
It’s possible that the above module doesn’t match the
current version of Python, which is:
2.6.6 (r266:84292, Nov 22 2013, 12:16:22)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-4)]
If you cannot solve this problem yourself, please go to
the yum faq at:
http://yum.baseurl.org/wiki/Faq
Yum on “yum update” throws messages like this (variables are not getting recognised?):
yum update
Loaded plugins: fastestmirror, priorities, refresh-packagekit
Loading mirror speeds from cached hostfile
http://SERIALNUMBER:LICENSEKEY@software.virtualmin.com/gpl/rhel/%24releasever/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - “The requested URL returned error: 404 Not Found”
Trying other mirror.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: virtualmin. Please verify its path and try again
Python is 2.6.6 version and it seems to be working.
How do i fix it to the way it was?
Thanks a lot
PS. just noticed it also done something to the mail over this! Mail does not work anymore - probably mail has some dependancies to this package! Please help to restore it?
