Bind not starting
Earlier today, I restarted BIND (along with all of my other services), and for some reason, it would not restart. I have tried restarting my server twice now, and BIND will not restart with the server, and when I try to start BIND in webmin it gives me the following error[code:1]Failed to start BIND : Unknown error[/code:1]
Does anyone know what could be causing this/how to fix it?
I bet there is still some dns issues.
check with the tools i suggested in the other thread untill it is completely correct.
If BIND wont start after that, some serious help is needed :slight_smile: cause unknown errors tend to have unknown solutions
ronald wrote:
If BIND wont start after that, some serious help is needed :) cause unknown errors tend to have unknown solutions
hehe, I like that Ronald, can I use it :wink:
