named.service - Berkeley Internet Name Domain (DNS)
Loaded: loaded (/usr/lib/systemd/system/named.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2018-05-17 11:49:26 -04; 3s ago
Process: 31482 ExecStartPre=/bin/bash -c if [ ! “$DISABLE_ZONE_CHECKING” == “yes” ]; then /usr/sbin/named-checkconf -z “$NAMEDCONF”;
may 17 11:49:26 localhost.localdomain bash[31482]: zone 1.0.0.127.in-addr.arpa/IN: loaded serial 0
may 17 11:49:26 localhost.localdomain bash[31482]: zone 0.in-addr.arpa/IN: loaded serial 0
may 17 11:49:26 localhost.localdomain bash[31482]: zone example.net/IN: NS ‘ns1.example.net’ has no address records (A or AAAA)
may 17 11:49:26 localhost.localdomain bash[31482]: zone example.net/IN: NS ‘ns2.example.net’ has no address records (A or AAAA)
may 17 11:49:26 localhost.localdomain bash[31482]: zone example.net/IN: not loaded due to errors.
may 17 11:49:26 localhost.localdomain bash[31482]: _default/example.net/IN: bad zone
may 17 11:49:26 localhost.localdomain systemd[1]: named.service: Control process exited, code=exited status=1
may 17 11:49:26 localhost.localdomain systemd[1]: Failed to start Berkeley Internet Name Domain (DNS).
may 17 11:49:26 localhost.localdomain systemd[1]: named.service: Unit entered failed state.
may 17 11:49:26 localhost.localdomain systemd[1]: named.service: Failed with result ‘exit-code’.
/var/named/example.net.hosts in webmin
$ttl 38400
example.net. IN SOA example.net. leobruni17.gmail.com. (
1526566500
10800
3600
604800
38400 )
example.net. IN NS example.net.
example.net. IN A 192.160.0.105
example.net. IN NS ns1.example.net.
example.net. IN NS ns2.example.net.
i’ve been having this error trying to setting up the BIND for a web local server.
