I´ve CentOS Linux 7.9.2009 - BIND DNS Server - BIND version 9.11
The following errors appear:
" Warning : Webmin thinks that BIND is not using a chroot directory, but that may be incorrect. The zone files for 2 domains could not be found.
**Make sure that the chroot directory is set correctly on the [module configuration]
When I checked the configuration the following error show
“Errors were found in your system’s BIND configuration : zone dominioAAA.net /IN: loading from master file /var/named/dominioAAA.net.hosts failed: file not found, zone dominioAAA.net/IN: not loaded due to errors., _ddominioAAA.net …”
Thank you for your help
