I upgraded webmin’s latest ver after many months from 1900 to 1932 today and it stopped DNS BIND 9.11 and complained of
“This domain has email enabled, but none of the MX records point to it. Either the MX records should be corrected, or the email feature disabled if mail is hosted externally.” + ProFTPD virtual FTP : No ProFTPD virtual server found
I then disabled mail service for all 4 domains and also ProFTPD from all domains
I am on a Centos 7* and have similar install on another machine but i hv not upgraded to webmin 1932 fear of getting into problems.
I am very desperate as i can not find any way to fix the following issue.
After i tried to start BIND BUT it gives following :
GeoIP City (IPv4) (type 2) DB not available
I have restarted RNDC a few times but to no avail.
Nov 15 16:09:01 um-2277 bash: zone localhost.localdomain/IN: loaded serial 0
Nov 15 16:09:01 um-2277 bash: zone localhost/IN: loaded serial 0
Nov 15 16:09:01 um-2277 bash: zone 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/IN: loaded serial 0
Nov 15 16:09:01 um-2277 bash: zone 1.0.0.127.in-addr.arpa/IN: loaded serial 0
Nov 15 16:09:01 um-2277 bash: zone 0.in-addr.arpa/IN: loaded serial 0
Nov 15 16:09:01 um-2277 bash: /var/named/domone.com.hosts:21: ignoring out-of-zone data (um-2277)
Nov 15 16:09:01 um-2277 bash: zone domone.com/IN: loaded serial 1518478438
Nov 15 16:09:01 um-2277 bash: /var/named/dom2.com.hosts:15: ignoring out-of-zone data (www)
Nov 15 16:09:01 um-2277 bash: zone dom2.com/IN: loaded serial 1519348436
Nov 15 16:09:01 um-2277 bash: /var/named/dom3.com.hosts:15: ignoring out-of-zone data (www)
Nov 15 16:09:01 um-2277 bash: zone dom3.com/IN: loaded serial 1519411691
Nov 15 16:09:01 um-2277 bash: /var/named/dom4.com.hosts:15: ignoring out-of-zone data (www)
Nov 15 16:09:01 um-2277 bash: zone dom4.com/IN: loaded serial 1519429126
Nov 15 16:09:01 um-2277 bash: /var/named/dom5.com.hosts:15: ignoring out-of-zone data (www)
Nov 15 16:09:01 um-2277 bash: zone dom5.com/IN: loaded serial 1519437476
Nov 15 16:09:01 um-2277 named[3709]: starting BIND 9.11.4-P2-RedHat-9.11.4-9.P2.el7 (Extended Support Version) id:7107deb
Nov 15 16:09:01 um-2277 named[3709]: running on Linux x86_64 3.10.0-1062.4.3.el7.x86_64 #1 SMP Wed Nov 13 23:58:53 UTC 2019
Nov 15 16:09:01 um-2277 named[3709]: built with ‘–build=x86_64-redhat-linux-gnu’ ‘–host=x86_64-redhat-linux-gnu’ ‘–program-prefix=’ ‘–disable-dependency-tracking’ ‘–prefix=/usr’ ‘–exec-prefix=/usr’ ‘–bindir=/usr/bin’ ‘–sbindir=/usr/sbin’ ‘–sysconfdir=/etc’ ‘–datadir=/usr/share’ ‘–includedir=/usr/include’ ‘–libdir=/usr/lib64’ ‘–libexecdir=/usr/libexec’ ‘–sharedstatedir=/var/lib’ ‘–mandir=/usr/share/man’ ‘–infodir=/usr/share/info’ ‘–with-python=/usr/bin/python’ ‘–with-libtool’ ‘–localstatedir=/var’ ‘–enable-threads’ ‘–enable-ipv6’ ‘–enable-filter-aaaa’ ‘–enable-rrl’ ‘–with-pic’ ‘–disable-static’ ‘–includedir=/usr/include/bind9’ ‘–with-geoip’ ‘–with-libidn’ ‘–enable-openssl-hash’ ‘–enable-native-pkcs11’ ‘–with-pkcs11=/usr/lib64/pkcs11/libsofthsm2.so’ ‘–with-dlopen=yes’ ‘–with-dlz-ldap=yes’ ‘–with-dlz-postgres=yes’ ‘–with-dlz-mysql=yes’ ‘–with-dlz-filesystem=yes’ ‘–with-dlz-bdb=yes’ ‘–with-gssapi=yes’ ‘–disable-isc-spnego’ ‘–with-lmdb=no’ ‘–with-atf=yes’ ‘–enable-fixed-rrset’ ‘–with-tuning=large’ ‘–with-docbook-xsl=/usr/share/sgml/docbook/xsl-stylesheets’ ‘–enable-full-report’ ‘build_alias=x86_64-redhat-linux-gnu’ ‘host_alias=x86_64-redhat-linux-gnu’ ‘CFLAGS= -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic’ 'LDFLAGS=-Wl,-z,relro ’ ‘CPPFLAGS= -DDIG_SIGCHASE’
Nov 15 16:09:01 um-2277 named[3709]: running as: named -u named -c /etc/named.conf
Nov 15 16:09:01 um-2277 named[3709]: compiled by GCC 4.8.5 20150623 (Red Hat 4.8.5-39)
Nov 15 16:09:01 um-2277 named[3709]: compiled with OpenSSL version: OpenSSL 1.0.2k 26 Jan 2017
Nov 15 16:09:01 um-2277 named[3709]: linked to OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
Nov 15 16:09:01 um-2277 named[3709]: compiled with libxml2 version: 2.9.1
Nov 15 16:09:01 um-2277 named[3709]: linked to libxml2 version: 20901
Nov 15 16:09:01 um-2277 named[3709]: compiled with zlib version: 1.2.7
Nov 15 16:09:01 um-2277 named[3709]: linked to zlib version: 1.2.7
Nov 15 16:09:01 um-2277 named[3709]: threads support is enabled
Nov 15 16:09:01 um-2277 named[3709]: ----------------------------------------------------
Nov 15 16:09:01 um-2277 named[3709]: BIND 9 is maintained by Internet Systems Consortium,
Nov 15 16:09:01 um-2277 named[3709]: Inc. (ISC), a non-profit 501©(3) public-benefit
Nov 15 16:09:01 um-2277 named[3709]: corporation. Support and training for BIND 9 are
Nov 15 16:09:01 um-2277 named[3709]: available at https://www.isc.org/support
Nov 15 16:09:01 um-2277 named[3709]: adjusted limit on open files from 4096 to 1048576
Nov 15 16:09:01 um-2277 named[3709]: found 24 CPUs, using 24 worker threads
Nov 15 16:09:01 um-2277 named[3709]: using 23 UDP listeners per interface
Nov 15 16:09:01 um-2277 named[3709]: using up to 21000 sockets
Nov 15 16:09:01 um-2277 named[3709]: loading configuration from ‘/etc/named.conf’
Nov 15 16:09:01 um-2277 named[3709]: reading built-in trust anchors from file ‘/etc/named.iscdlv.key’
Nov 15 16:09:01 um-2277 named[3709]: initializing GeoIP Country (IPv4) (type 1) DB
Nov 15 16:09:01 um-2277 named[3709]: GEO-106FREE 20180327 Build 1 Copyright © 2018 MaxMind Inc All Rights Reserved
Nov 15 16:09:01 um-2277 named[3709]: initializing GeoIP Country (IPv6) (type 12) DB
Nov 15 16:09:01 um-2277 named[3709]: GEO-106FREE 20180605 Build 1 Copyright © 2018 MaxMind Inc All Rights Reserved
Nov 15 16:09:01 um-2277 named[3709]: GeoIP City (IPv4) (type 2) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP City (IPv4) (type 6) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP City (IPv6) (type 30) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP City (IPv6) (type 31) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP Region (type 3) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP Region (type 7) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP ISP (type 4) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP Org (type 5) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP AS (type 9) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP Domain (type 11) DB not available
Nov 15 16:09:01 um-2277 named[3709]: GeoIP NetSpeed (type 10) DB not available
Nov 15 16:09:01 um-2277 named[3709]: using default UDP/IPv4 port range: [32768, 60999]
Nov 15 16:09:01 um-2277 named[3709]: using default UDP/IPv6 port range: [32768, 60999]
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface lo, 127.0.0.1#53
Nov 15 16:09:01 um-2277 named[3709]: binding TCP socket: address in use
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface eno1, 69.61.xx.x #53
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface eno1:1, 69.61.xx.x#53
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface eno1:2, 69.61.xx.xx#53
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface eno1:3, 69.61.xx.xx#53
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv4 interface eno1:4, 69.61.79.110#53
Nov 15 16:09:01 um-2277 named[3709]: listening on IPv6 interface lo, ::1#53
Nov 15 16:09:01 um-2277 named[3709]: unable to listen on any configured interfaces
Nov 15 16:09:01 um-2277 named[3709]: loading configuration: failure
Nov 15 16:09:01 um-2277 named[3709]: exiting (due to fatal error)
Nov 15 16:09:01 um-2277 systemd: named.service: control process exited, code=exited status=1
Nov 15 16:09:01 um-2277 systemd: Failed to start Berkeley Internet Name Domain (DNS).
Nov 15 16:09:01 um-2277 systemd: Unit named.service entered failed state.
Nov 15 16:09:01 um-2277 systemd: named.service failed.
