If I understand the format correctly…
openstream.ch:openstream.ch:password:openstream:::
openstream.net:openstream.net:password:openstream:openstream.ch::
This should work… It does to a point though.
The shared IP is never used… it just leaves that blank but according to the help doc…
ip-address
For virtual servers that do not need their own private IP, this field can be left blank. Otherwise, you must either enter a valid un-used address, or the word allocate to have Virtualmin select one for you (if configured).
I assumed that if left blank the main shared IP from the default interface would be used. Am I wrong here?<br><br>Post edited by: sgrayban, at: 2007/09/04 11:06
