hiro
November 9, 2011, 7:43am
1
Hi!
I has run virtualmin for 3 months. It’s realy good. I love it.
But last night I uploaded some file decoded by base64. I can’t open it, it show blank page.
I think it miss some library and I use “yum search base64”. I install some library i found but i can’t open that files.
Please help me this problem!
Thanks!
Eric
November 9, 2011, 3:33pm
2
So, you’re saying you have text encoded with base64, and you’re looking to convert that to plain text?
While a base64 library would be needed for that – the library itself isn’t enough, you’d need to to actually perform the translation.
You could always cut and paste your base64 encoded text into a site such as this to decode it:
http://base64decode.org/
hiro
November 9, 2011, 3:43pm
3
no! I means how can my server can read file decoded by base64.
Eric
November 9, 2011, 4:06pm
4
Hrm, I’m a bit confused as to what you’re trying to do
Can you describe in detail what exactly you have, and what you need?
helpmin
November 10, 2011, 10:15am
5
After yum install base64
. You would just do base64 -d yourfile
or so. but this is not really a virtualmin related question (wrong forum :-).
If you downloaded some php base64 encoded files, I would be make sure first that they come from a trusted source.
