Hi I hope someone can please help. I have a readynas nv+ and I want to backup my virtualmin/webmin and all server files to it as a compressed tar/zip etc file…
I’d hoped to have a full backup once per week at least, or maybe with nightly incremental backups.
Now I’ve tried and tried via the built in backup filesystem module and tried with bacula and I can’t get anything to work.
After much trying I realised that bacula needs to run also on the backup machine so this is no good.
I nearly got the build in filesystem backup to work but again I get an error:
As your NAS is in your local network, the easiest way is to put the FTP server of your NAS on. After that, point your backup to your new FTP account. I do like that and it works perfectly.
I join an example of my config in the pdf file
“x” letters" are for the IP adress
“y” letters are for the MAC address, if your NAS is often on S4 mode and wake-on-lan capable
“%Y-%m-%d” allows you to call backup files with the date of day.
Hi thanks - I was hoping to back up the whole server though from webmin/virtualmin rather than the virtual servers - is there a way to do this to a NAS?
You can try what you want by using “Webmin > System > Filesystem backup”. With this command, you will be able to backup all the folders you want (for instance /etc, /usr, …). To restore your files, you will have to copy+paste them via FTP or SSH.
Faster than that and maybe more careful, I advise you to backup the virtual servers and the webmin configuration files (“Webmin > backup configuration files” and choose what you want to be backed up - Apache, Postfix, Dovecot …). The restore engine will reinstall all the /etc; /usr, /var /home … files for your apps (Apache, Postfix, Dovecot … ) and for your virtual servers if needed.
Filesystem backup looks cool, but I couldn’t get it to work. I put my host address 192.168.0.2 which is my NAS. but could my nas be not compatible with this way of backing up as it mentions rtm path and seems like you may have to install something on the host before it will work?
It would be unusual that your NAS can not get FTP connection, unless there is a firewall rule (on webmin or, more probably, on the NAS).
If there is no firewall issue and the FTP is running on the NAS, maybe you didn’t configure the “Filesystem backup” correctly. You have just to fill in the “TAR filesystem backup details” part of the form to make the basics work.
first of all, choose the “directories to backup” (for instance, /etc)
in the “backup to” section, choose FTP and put your configuration parameters. No problem for the IP, userneme and password, but be careful for the name of the backup file. You have to put the .tar.gz extension to your backup file (e.g. /path/to/backup/file.tar.gz), even if you didn’t tick the “in TAR format” when you created the scheduled backup. Perhaps the .tar extension works well, but I didn’t try.
Hi thanks I’ve tried this as you said putting tar.gz in the file or device to backup to. (But there is a backup ‘label’ field in Backup Options further down?
It still doesn’t work and I get these errors;
“tar: Removing leading `/’ from member names admin@192.168.0.2’s password:
tar (child): admin@192.168.0.2:HY_LocalServerBackup.tar.gz: Cannot open: Input/output error
tar (child): Error is not recoverable: exiting now”
virtualmin seems to have some trouble to make the archive. This issue comes generally from the mean you use to specify the path of your file (absolute path or relative path).
I join an example of working config. In my case, the backup are sent to a FTP server wich is hosted by an IIS server, but I think it doesn’t matter.
Note that :
I didn’t tick the “in TAR format” when I created this schedule (but it could be interesting in your case)
you can replace the file name “backup.tar.gz” by “%Y-%m-%d.tar.gz” if you have activate the strftime in the module config.
if your NAS is always on, you can remove the “ether-wake && sleep” command.
Hi I’m really sorry I’ve copied all your settings and suggestions but I still get the same errors.
tar (child): admin@192.168.0.2:HYlocalserverBackup.tar.gz: Cannot open: Input/output error
admin@192.168.0.2\ doesn’t look right to me on there?? I’m not sure how that is getting added, but could that be the problem?
