Sorry, I don’t know English well. The region is not Region > (EU)??
That is the url (end point) reading the rest of the contabo document they dont appear to have a region setting it is part of the end point, so copy and paste that url in to the end point field and save it and see if virtualmin excepts it
What has this got to do with this issue ? Are you supplying unrequired links ?
Yes that and the url/end point from the previous picture
No problem, I have deleted it, I thought it might help somebody to use as a cheap backup system that you can also run Virtualmin on. I move my backups using ssh and have cron scripts set up to do it all
Thanks for the help! I managed to do it and set up Storage correctly. Now I need to solve the problem with SQL Dump.
These instructions that I have to write to her??
No. That script has nothing to do with your question, I’ll remove it, it’s off-topic.
Nothing to solve there just use virtualmin backups as suggested in your last picture
and everything will work as expected, I see from your other thread you are using webmin rather than virtualmin, as you are a virtualmin user just use virtualmin … In the last decade a virtualmin backup has never failed to restore, what I wanted/needed to restore, correctly
Thank you, I have solved the problem with the backup contabo storage.
