Ok the restore failed but Ive fixed the problem why this happened but there are the backup files I uploaded stored? if they still are? ,Ive just spent 4 hours uploading only for it to have failed. Are they still on the server somewhere?
please tell me they are
I restored via the âRestore Backupâ on the virtualmin backup and restore
Ah, are you saying that, when performing the restore â you used an FTP Server as the source for the backup file?
If thatâs the case, Virtualmin would not keep the backup locally after performing the restore.
That is, it would copy it locally, into /tmp/.webmin by default, perform the restore, and then delete the local copy â preserving only the copy on the FTP server.
You can of course double-check that it was in fact removed from /tmp/.webmin, but in theory the only remaining copy should be on that FTP server.
If you intend to perform the restore multiple times without re-uploading, you need to transfer the backup file to the target server beforehand, e.g. through SCP, and then use that local file as restore source.
