Backup Problems "Interrupted system call"
My backups will just not work anymore keeps giving me the same error
Starting backup of 16 domains to /%d %m %Y on FTP server 82.******* …
Failed to connect to FTP server : Failed to connect to 82.********:21 : Interrupted system call
Backup failed! See the progress output above for the reason why.
Anyone any idea why I am getting this? it was working just fine
Cheers
Are you able to connect from your Virtualmin server to the FTP server using the command line FTP program?
Also, is your Virtualmin server running on a VPS? If so, what kind of VPS is it?
Hey Eric yea it was my end which was the problem sorry about that.
Cheers
Mike
