if DocomentRoot is set inside domains folder like this:
DocumentRoot ${HOME}/domains/${DOM}/public_html
it is not included in backup becourse “./domains” is hardcoded to put in exclude file
Hi Alex
You are right that it is excluded from backups. However, the default option during backup configuration is for the checkbox under ‘Servers to save’ labelled ‘Include sub-servers of those selected’ to be checked - this would also include the ${HOME}/domains/${DOM}/public_html
folder in the backup for you if you are choosing to backup the server’s home directory.
You haven’t actually asked a question in your post, so if I haven’t provided what you wanted to know, feel free to reply - but please include an actual question.
