Hi there,
I’m seeing the following error for all of my awstats enabled sites:
[code:1]
Error: Not same number of records of BrowsersSearchIDOrder (164 entries) and BrowsersHashIDLib
(165 entries without msie,netscape,firefox)
in Browsers database. May be you updated AWStats without updating
browsers.pm file or you made changed into browsers.pm not correctly.
Check your file /usr/share/awstats/lib/browsers.pm is up to date.
Setup (’/etc/awstats/awstats.michaelwulf.com.conf’ file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in ‘docs’ directory).
[/code:1]
I tried checking out browsers.pm, but short of writing perl script to compare the two arrays, I can’t make heads or tails of that. I attached it for added fun. [file name=browsers.txt size=18662]http://www.virtualmin.com/components/com_fireboard/uploaded/files/browsers.txt[/file]
Here’s some relevant info:
[code:1]
[root@server lib]# yum list awstats
awstats.noarch 6.8-1.el4 installed
[root@server awstats]# ls -l awstats.michaelwulf.com.conf
-rw-r–r-- 1 root root 58729 Jul 29 10:36 awstats.michaelwulf.com.conf
[/code:1]
Post edited by: kato, at: 2008/10/15 05:33
Post edited by: kato, at: 2008/10/15 05:34<br><br>Post edited by: kato, at: 2008/10/15 05:35
