Running into issues with install.sh on Ubuntu 14.04
Everything seem to succeed up until this point:
E: Unable to locate package webmin-core
The next set of errors are
E: Unable to locate package usermin
E: Unable to locate package procmail-wrapper
E: Unable to locate package scponly
Then the log:
INFO - 2016-02-09 19:00:50 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-09 19:00:50 - Install mode: full
DEBUG - 2016-02-09 19:00:50 - Product: Virtualmin GPL
DEBUG - 2016-02-09 19:00:50 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-09 19:00:50 - install.sh version: 1.1.2
INFO - 2016-02-09 19:00:50 - Checking for fully qualified hostname...
INFO - 2016-02-09 19:00:50 - Hostname OK: fully qualified as XXXXX.XXXXXXXXX.com
INFO - 2016-02-09 19:00:51 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-09 19:00:51 - Loading OS selection library...
INFO - 2016-02-09 19:00:51 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-09 19:00:51 - Loading OS list...
INFO - 2016-02-09 19:00:51 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-09 19:00:51 - Operating system name: Ubuntu Linux
INFO - 2016-02-09 19:00:51 - Operating system version: 14.04.3
INFO - 2016-02-09 19:00:51 - Configuring package manager for Ubuntu Linux 14.04.3...
INFO - 2016-02-09 19:00:51 - Enabling universe repositories, if not already available...
INFO - 2016-02-09 19:00:51 - Disabling cdrom repositories...
INFO - 2016-02-09 19:00:57 - Cleaning up apt headers and packages, so we can start fresh...
INFO - 2016-02-09 19:00:57 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2016-02-09 19:00:57 - Installing Webmin and Virtualmin package signing keys...
INFO - 2016-02-09 19:00:57 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2016-02-09 19:00:57 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2016-02-09 19:00:57 - OK
INFO - 2016-02-09 19:00:58 - OK
INFO - 2016-02-09 19:01:03 - Ign
INFO - 2016-02-09 19:01:03 - Removing Debian standard Webmin package, if they exist...
INFO - 2016-02-09 19:01:03 - Removing Debian apache packages...
DEBUG - 2016-02-09 19:01:04 - Reading
INFO - 2016-02-09 19:01:04 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install bsdutils postfix postfix-pcre webmin usermin ruby libxml-simple-perl libcrypt-ssleay-perl unzi
p zip libfcgi-dev bind9 spamassassin spamc procmail procmail-wrapper libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common pos
tgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-c
ustom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libapache2-mod-php5 php5-mysql
Reading package lists...
Building dependency tree...
Reading state information...
FATAL - 2016-02-09 19:01:05 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2016-02-09 19:01:05 - Cannot continue installation.
FATAL - 2016-02-09 19:01:05 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-09 19:01:05 - re-attempted after any problems have been resolved.
FATAL - 2016-02-09 19:01:05 - Removing temporary directory and files.
FATAL - 2016-02-09 19:01:05 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-09 19:01:05 - in /root/virtualmin-install.log
The only other post I saw that mentioned that error of being unable to locate the package for webmin-core was an unsupported version of Ubuntu. But 14.04 LTS is supported, yes?
It should actually install onto Ubuntu 14.04 with no problems.
It makes it sounds as if it wasn’t setting up the repository correctly. Or perhaps there was something confusing it about how to look for packages for your distro… though I’m not sure what that would be.
Your fix should be just fine, however, I’m curious what the output of this command is:
