I’m just testing around with the templates here and trying to automatically loads scripts on account creation.
When I create template test I then click on the scripts link in the template listing (it says default) and try to add a script it wants a path, so I insert /public_html and apply it.
What happens then is that the test template again says default and the default template says 1.
If I go through the same process again with a different script the test template again says default and the default template says 1, but this time listing only the most recent script inclusion. If I go to the default template, I can add any number of scripts to install.
Is this a bug or just me? And just out of curiousity what is supposed to be the path for these. I note that the scripts get installed into the /public_html/public_html
thanks,
Dan
