I want to install a SVN Server under Virtualmin. The doc (http://www.virtualmin.com/documentation/web/svn ) says, I must only run the apt-get install webmin-virtualmin-svn. But the system cant find the package…
I ran apt-get install subversion and apt-get update too… But it will not work.
Can anybody help me please?
Eric
September 8, 2010, 7:56pm
2
How did you install Virtualmin, did you use the install.sh script?
When you run “apt-get update”, and it contacts software.virtualmin.com , do you see any errors or warnings?
Uh, I see that I dont have software.virtualmin.com in the apt-get list…
I have installed Virtualmin after webmin, and I dont know how I did it… It was a long time ago. Can I see this anywhere?
I’ll add software.virtualmin.com now and try it again, Thank you.
Edit: Mh, I dont know the correct adress (deb http://software.virtualmin.com sarge contrib ?) for the source.list
Eric
September 10, 2010, 12:28am
4
Ah, yeah, you wouldn’t have the Virtualmin repository in that case…
If you installed Virtualmin as a module, you wouldn’t be able to use the webmin-virtualmin-svn package.
You could, however, install the virtualmin-svn module.
To do that, browse to:
http://software.virtualmin.com/gpl/wbm/
Download the module(s) you want, and then you can go into Webmin -> Webmin Configuration -> Webmin Modules to install the modules you’ve downloaded.
Ok, thank you very much for the help, but the repository won’t work. Always when I want to Checkout, it says
ERROR OPTIONS from »http://svn.gamers4life.de/svn/Test«: 200 OK (http://svn.gamers4life.de )
I have the libsvn1module.
