Apparently Bind9 is not running
Hey,
I have installed Webmin 1.4 and Virtualmin 3.53 GPL, however when I go to Virtualmin Servers GPL it says that Bind9 is not running, when in fact, Bind9 is very much alive and kicking.
What could be causing this? It’s quite annoying since when I make a new virtual server - I am having to manually restart bind.
Regards,
Alex Cartwright
Fixed =) For people who have the same problem:
I was running Bind9 chrooted, and was unaware I had to configure the Bind module to reflect this configuration. What I had to do was as follows:
Go to Servers->Bind DNS Server and follow the link labelled ‘Module Config’. From there you need to change:
Chroot directory to run BIND under => /var/lib/named/ (if that is where yours is)
Is named.conf under chroot directory? => No
Command to start BIND => /etc/init.d/bind9 start
Command to stop BIND => /etc/init.d/bind9 stop
Hit ‘Save’ and it’s all done =)
